manurules3
Hey guys I'm in need of a little help. I'm currently running Liberty on a .886 Bionic and I was wondering what steps do I need to take to get it to .902 with root. Thanks for any responses!!
Hmm.. I have quite a few backups one of which is stock but I'm not sure which is which. Is there a way to tell? Or is it hit and miss?
When you rename the backups don't put a space between the names in the file, it will mess up the md5 sum and you won't be able to use it to restore . Write it with an under score between them like_this.
