Accessories Going on an Incredible shopping spree
For another six bucks you could make it a 16gig card if you look hard enough. Other then that I think it looks pretty great
Is the new memory card the same as one you get for a digital camera? Also, I assume the Incredible comes with a wall charger and a USB cable. Is this correct? (just figuring out what i need to get as well before my phone arrives!)
I don't know of any camera which uses the MicroSD, which is what the phones use. So make sure that you get a Micro one, not a regular one.
Yes, it comes with those.
yes you are correct but i would defiantly look into buying a case or a screen protecter before your incredible comes so you can apply it as soon as you take your phone out of the box.
I agree! Expecially if you are going with one of the wet application ones like Zagg (what I am using). Apply it after opening the box and then it will have plently of time to dry and set while you do your initial charge.
