I would make one just in case. You can always transfer it to your pc or delete it in the future. Only takes a couple minutes to do while you are in recovery
Ok, will do. Thank you. But do I have everything else right in my post?, As far as the "caulkins" stuff?
Just out of curiousity, why the switch from MikFroyo to this new one? Not questioning you at all, just that I use MikFroyo and am always down to flash a new rom but not just any of them.
What do you like about the rom you are flashing to?
thanks
So those issues you are having with MikFroyo? I have not had those issues before. And I got my customized lock screen to work where it's a sliding bar and I have access to messages, music, sound and one other option I added. Some of it's a pain though to flash.
Unless you mean you are having those issues on Virus.
But I will give this a try maybe. also need to try Fresh and Sprint Lovers from reading around.
Thanks man!
Yeah so far I have tried Cyanogen (hated it!), Myns and MikFroyo (currently using)
Yeah if it is not big on theming, I will probably pass on it.
Ok guys, I officially switched roms. I am currently running VirusROM Airborne RC6 Public BETA 1. Very nice rom, I love the UI. Havent had any FC issues. Definetly the rom I was looking for.
Battery life is much than what I had on Mikfroyo. I just now dropped down to 72% and thats after heavy use this morning (10hours, on 3500mah). I did try to do the PRL hack over on xda, But I ended up without a signal for about an hour I was finally able to update my sprint prl.
But I really like this new rom, the full hdmi is very nice.
You need roaming UNCHECKED when using that hack (just a thought, I had issues with that one also), also that prl is iffy for some, there is a "full 3g prl" thread here in this forum with links to other prls. I have a list of like 10 that i try. Oddly i went back to the first one because i may flux signal but my 3g speed is amazing. There are vzwsprint prls and a modified sprint 60665 prl.
hmmm...no signal to update prl...i would have committed a diff prl and tried again. There is the 60665 mod prl out there which is probably a safe haven to commit to if you get stuck like that again. I use the ones from the first thread still, the O-riginal. I dont get signal at work unless i use one of them. I tried the ones from the full 3g thread here (the newer xda thread) and they didnt give me as drastic 3g speeds at work, the only place i really use them. I use wifi at home so im not too woried about pissing sprint off.
It would seem that our original prls such as 60665, 66, and 67 should be out there somewhere in a .prl file form in case we need to go back and dont have signal...?
Yeah, I'm not too worried about pissing sprint off either. The only time i'd use the roaming 3g would be at work, and I wouldnt be downloading gb's of crap. I was getting awesome 3g speeds at work a few weeks back. Like 1000kpbs download speeds. And I was getting a little 4g signal. But since then my 3g speeds have dropped to around 250, and no more 4g signal. So either they are upgrading something, or not.
And yes, I wondered if anyone had the orginal prls for us, just as a safe precaution in case of a situation like mine. The reason why I freaked out so bad was because I didnt see anyone not being able to get a signal to at least go back to a stock prl.
