marc12868
Android Expert
I'm thinking of making the switch too. I'd maybe go with the G2x or the GSII. I want something with at least a 4" screen and equal or better specs than the MT. What other phones did you consider moving on to?
Well for me it was just what I could get for cheapest for new or in like new condition from craigslist or ebay. If I wanted to go all out and get one for whatever price I probably would get the GS2 (which is just pure power using both cores), or the HTC Amaze. But the G2x looks good and I was gonna get one, but the guy just stopped contact me. But it just depends on what you want. The GS2 is basically just raw, unhindered power using both cores at once which could be good or bad depending on what you are doing. The Mytouch 4g slide has 2 cores, but they are a bit more organized with one processor being used by the app in focus then everything else that runs in the background on the second core. The G2x has tegra 2 chipset so it just has good graphics and gaming performance. The amaze is like the GS2 I believe just a bit weaker. So it really just depends on what your willing to spend and what you want. Like me I wanted something around 2-300 hundred that was 4g capable and has dual cores. If you want HDMI out though you I think the Mytouch is the only one of their 5 dualcore 4g android phones that doesn't have it.
Edit: also I guess it depends on what overlay you want... G2x is like stock gingerbread, htc amaze, htc sensation, and htc mytouch all have sense 3.0 (well the mytouch has the espresso build), and the GS2 has Touchwiz 4.0. So that also can factor in. Personally I don't really care and I can always root and install a custom rom that is sense free.
. In case anyone is thinking of switching and want to know more about the Mytouch that reviews don't show... It can detect 4 points of input flawlessy no snapping. Built in flashlight with 3 brightness settings and is fairly bright. Screen is a hell of lot brighter and more vibrant than the MTs. Has a notification light! Superior camera (better be since HTC and T-Mo is advertising it as the "best" camera in the smartphone industry). I'll let you know more as I have explored it more.
It may not happen, but it's a dream of mine
