Gold battery
iDapzZ
My battery life is atrocious. Does anybody know if the gold battery's are any good I believe their 4350mah many thanks in advance
I don't think that it will fit within the original phone's case.
it takes more mass/density to give more power, there for, a battery that has twice the capacity of the OEM battery is going to be very near twice as thick.
No they are the same size their on ebay and Amazon just curious as to wether their safe or not don't want it to explode
I have no way of knowing that, if it is a 3rd party manufacturer, do a search for that manufacturer's name and that battery number. you should be able to find some comments on how good it might be.
If they're on Ebay, they're very likely from China, claims about capacity are BS, and just might explode on you.
I've seen them here with ludicrous claims about capacity. Their capacity is actually less than the original Samsung battery, and likely padded out with sawdust or donkey poo.
Does anyone have a good battery to suggest just mine is really bad lost 10% in about 10 - 15 minutes of usage
MikeDT just emphasized what I was trying to tell the OP about Larger Mass/More Density/Better Chemistry....
as of today, the Li-Ion technology is pretty stable, and if a battery proclaims twice the power, it will HAVE TO BE twice as massive. It cannot possibly maintain the same exact case dimensions.
the Donkey Poo statement is a lot more correct than the Specifications you are reading from "Gold Battery".
CAVEAT EMPTOR and run like hell.
