I'm excited to say I just ordered an S23 FE to replace my S9.
I'm told Smart Switch can or will make it easy to migrate my stuff over, but I have questions:
1. An employee at the T-Mobile store told me I can pick and choose what I want migrated over. For example, if I just want my contacts copied, I can do that, right?
2. I'm kinda worried I might have some contacts stored on my S9's internal memory vs some stored on its SIM card. How do I figure this part out?
3. When it comes to apps, would I be correct in thinking Smart Switch will copy them over with their saved preference files and logins intact?
4. Does Smart Switch simply copy your apps over, or is it "smart" enough to go to the Play Store and download and install on your new phone the same apps you had on your previous phone?
5. Given how old the S9 is, and given how much old and extraneous apps can gunk up your system, my gut instinct is that it might be better to not copy any apps over, and that I should instead go to the Play Store on my own and do fresh, clean installs of every app I want to continue using. Am I correct in thinking this is a better, smarter option?
6. If I do want Smart Switch to copy apps over, does it allow me to pick and choose which ones, or would this be like Apple's Migration Assistant for Macintosh, where it's pretty much all the apps or none?
7. The lady at the T-Mobile store suggested I do this all over Bluetooth. Isn't Bluetooth hella slow, though? She did say I could use a USB cable to accomplish this if I wanted to. Would USB be better and faster?
8. And speaking of T-Mobile, while I am a T-Mobile customer, I ordered this unlocked phone on Amazon, 'cause T-Mobile doesn't sell this model with 256GB of storage. I'm planning to install the T-Mobile Visual Voice Mail app. Are there any other apps or utilities I, as a T-Mobile user, should be installing in order to get the best out of my service?
9. I've never signed up for Samsung or T-Mobile's cloud backup services, but I figure I ought to, since my whole life is on my phone. Whose cloud backup, if any, do y'all recommend?
10. Should I used Smart Switch to migrate over all my old, existing text messages? It's nice to think of not losing them, but I dunno, maybe I'm gumming up the works if I carry over years of old messages? Is it better to just get a clean start?
Thank you for your guidance!
