Root Good Rom With Hotspot Ability
So i've been searching through the threads, I'm looking for a rom that will allow for wifi tether or native hotspot. Recommendations?
Just root your stock rom and use the sqlite hack foe Hotspot. Or amy stoxk based rom.
Any source built rom wont be perfect but it goes as follows
Cm11 Kitkat
Aoko Kitkat
Paranoid Kitkat
MiuiV5 Jellybean
Slim rom Kitkat
Those are probably the most popular right now
My Bionx rom supports tethweing but again, u have to use the sqlite hack
I'm not familiar with that hack. Can you give me a link? Also I didn't see a DL for you rom on your thread it said closed, and not seem amy's stock rom around. I've tried installing CM11 but it fails for some reason.
I host my roms on xda developers and on my Nx Industries website (www.bionx.webs.com)
Il see if i can find a link. If the roms arnt installing correctly than you are missing something or ull need to RSDlite first
I just saw roms for the LG Ally on your website. I'll try looking at xda. Some roms install, cm 10.2 works, Icy rom loads up but the hotspot feature crashes.
Than you didnt look hard enough ;) one of the main directories of the website is my current rom i support called Catalyst.
