Google calender not synced correctly
And_roid
Dear all,
I'm asked to support in/solve a problem, but until now things didn't work out. A Google calender is used at three platforms: online, at a Samsung Tab 7 and a Samsung Galaxy S2. Ofcourse; synchronisation is turned on at all Android devices.
If an appointment is created online (laptop, Windows 8, browser IE/Chrome), this appointment pops up in seconds at the Android devices. Works great so far.
However, if an appointment is made on an Android device, it doesn't show up at the online calender at the laptop. Even if the calender is refreshed or even reopened, it still doesn't show up. It looks like synchronisation is only one way.
If an existing appointment (which is available online at Android) is modified at Android, it also doesn't modify online. Though; when I open that appointment online, my modification shows up at the edit screen. Hence, synchronisation has worked half way?
I spend quite some time at it but can't solve it. I've read so many threads about synchronisation, but they tend to focus on synchronisation problems in which nothing is synced. Mine is synced, but not completely :-(.
As said, synchronisation is turned on at all devices. Further, the local calender on the Android device is turned off; only the Google calender is active.
Any help would be greatly welcome!
Thanks!
I have never owned a "skinned" Samsung device, but I am fairly sure (correct me if I'm wrong) that they can sync with Google, and they can also sync with Samsung. Might that be why it works from the web to the devices, but you're having problems going the other way?
