amit326
Hey Guys,
I've been facing this issue for a long time now and would highly appriciate any advise here ...
I have a nexus 5x.
I am using google keep's reminders but sadly I get a very short (one second) notification on the screen if the screen is on
or a notification short sound (shorter then usual notification sounds) when the screen is off.
There is no notification lasting on top of the screen that I can scroll and see like in the past.
It seems like something is blocking it,
I gave Google keep permissions to my contact, storage and everything that is possible.
I've enabled the locked screen notification on google keep's settings
I've also reinstalled google keep and it didn't help ..
I've downloaded many reminder apps like any.do and evernote but they face the same issue as I've mentioned above.
The only way I can get a reminder is if I put a reminder in google calander's built in app
But I don't want to use it
Would appreciate any help on your part.
Thanks.
I have a nexus 5x.
Thanks.
