I have an unrooted Droid Charge.
When I originally set up my phone, I also set up Google Latitude. It gave me the options to choose the accuracy of the GPS setting. It had 3 or 4 options. The ones I can remember are- About using cell tower (less accurate, uses less power)... The other I can kind of remember, Use GPS/phone location/etc... (uses most power, most accurate). Currently, this option is NOT in the options menu. I originally chose less power option. But, I want to change it back to most accurate.
Currently, my gps location is not always correct and the only time it is always completely accurate is when I have wifi enabled...
My blackberry, I chose the most accurate option and it it always accurate to "3 meters".
Btw, I am not referring to the "Location Reporting" menu.
Is there a way to fix this without hard reset?
I tried to uninstall Google Maps but, the only option was to uninstall updates. Once I did, it updated automatically within a few mins.
thank you your help!
