Help Google maps location problem
ColinBH
Hi. I accidentally opted out of letting Google Maps access my location. I cannot seem to get to opt in again. The instructions say:
For Browser (Android):
1. Go to Menu>More>Settings.
2. In Settings, go to Website>Settings>Google Maps Mini>Clear location settings
However; there is no 'menu' on my Galaxy Note 10.1 (or at least I cannot find it).
Can someone please help? Either tell me where the 'Menu' is so I can go to Menu>More>Settings etc, or tell me another simple way?
It would be greatly appreciated.
Thank you very much.
CBH
"Menu" is represented as three desending dots or lines in most applications. In the stock browser you will find it in the top right hand corner of the screen.
Yes a factory data reset should clear up the problem. Just be sure to allow google to use uour location when setting it up.
