What rom are you using? I'm on Angry Bean and it's working fine. I'll have to test it more later on when i go somewhere to check accuracy but I don't notice any flickering.
I'm also on angry bean but I'm about to update it, so let's see that helps
I do have same issues with Google map with old build and with new build too. Flickering when blue dot (me) is on the screen.Good luck! Even before the map update, I had none of these issues so maybe it was just a bad install?
I have uploaded to Mediafire the last version (6.14.4) before the latest update from my phone. I haven't received the latest update yet.
Maps.apk
It started with the Maps Update from the Play Store. First time I read about the issue I tried Navigation and had no issue. Thought the same at first about a bad or maybe dirty flash issue but then later saw the update for Maps in the Play Store and it started after downloading. I hope that its either a Google or CM issue with whatever was changed in the new Maps update and is resolved by one of those party's, would be nice if its the case otherwise if you have a backup of the previous version of Maps it works fine. I may need to track it down and post it but I did some messing around and after clearing data for Maps why on wifi I opened up Maps before Navigation and the accept terms came up that had not when I started with the Navigation icon first. After that I took a trip to the store and it seemed to be ok but the store is not all that far away. With that said the new update for Maps, at least on the Navigation side kind of sucks. Anyhow in short if you are still on the previous version of Maps and have not updated would recommend not checking auto update and stay on the previous version of Maps for now.
Maps.apk
Did anybody receive the new maps update with stock ICS ROM? Google says 4.0.3 is the minimum requirement but I still haven't received it. Just wondering if they blocked ICS completely.
In Developer options if you uncheck Disable HW overlays it got rid of the flickering issue for me.
