D
Deleted User
Guest
xda-developers - View Single Post - [App] Android Market patched to skip self-update and remove device restrictions
Took me a little bit to find these, so I thought I'd post it up.
If you modify your LCD density, and you aren't using one of the "stock" densities, you can have incompatibility errors in the Play store. If you're using a density of 160, you don't have to worry about this.
If you download and install the market APK of your choice from the above link, it will fix the issue.
Just installing the app didn't work for me. I had to:
- back up "/system/app/Phonesky.apk"
- use Root Explorer to copy the file I chose to /system/app
- change the permissions to look like the rest of the files (owner+rw, group+r, others+r)
- reboot
Boom, perfection.
- reboot
Boom, perfection.
