Help Google Play Download Problem
When I try to update OR down Apps from Google Play, it stays "waiting for Network" and tries to connect through WIFI even when my net is working through Data Package.
The download through WIFI is not selected in settings.
Pl help
Turn off wifi. If you are connected to wifi it will try to do any data through that.
Pl help
Try this, go into settings, then applications, and find Google Playstore.
Open the Google Playstore App and click on clear cache, then click on clear data.
This is what I recently had to do to solve the same issue I had on a different phone. Good Luck.:)
I just flashed Jetmod3.0 on my Micromax A50 but after that no applications are downloading from Google Play. It only shows 'Downloading...". I did use mobile network, but no problem with the network as I am getting gmails. I was trying to download Titanimum Backup Root to restore my apps. What could be the reason? Please help.
