PCNutt3r
I posted this over at the xda forums, but because there are so many posts my post seems to get forgotten about
I'm on LeeDroid 2.3D and did a clean install, both apps were working fine with stock firmware so pretty sure its not a hardware problem.
Here is my post:
Here is my post:
Only problem I have found with LeeDroid 2.3D (anyone else have this) is with Google Sky Maps. Installed and let apps2sd+ do its thing, however when I open the application its not rotating properly, some times not at all and when I located the moon it was not correct, it appears to be lost.
Was working fine on stock rom, I have calibrated the G-sensor with no luck, don
