Google tv box Unbranded cortex A9 wifi problem
Hi,
I bought google tv box unbranded. I have a problem with wifi. The connection is often unstable.
Although the connection said “saved”, si not possible to use it.
I would like to install android 4.xx to see if this solved my problem, but this device don’t have the reset key, so i don’t kwon how to do.
Can you help me?
Attached photo of my device
Try setting your wireless network to 802.11g mode only instead of having it run on b, g, and n it might make the connection more stable. Also don't have any special characters in the network name, keep it all letters with no spaces.
You sure there's no reset button anywhere on it even a tiny pin hole or something along those lines, maybe it's hidden within the casing, you might have to take it apart to see it.
FYI these aren't GoogleTV's they are Android set top boxes, GoogleTV's are a separate platform.
First: sorry for posting in wrong thread, please moderator/administrator adjusted it.
Asap i'll open the box to find the reset button. For setting wifi on mode g only it there insn't possibility to set it.
Thank you
