jsphmuckey
So I have a boost volt 2 I am unable to fix :/ Using a moto e for now till I can figure out a way to bypass google verification..
What happened:
So I had rooted using kingroot but think it was causing problems n I unrooted. Not knowing about Google verification I did a factory reset via stock recovery... Well I had uninstalled the stock keyboard n downloaded swype.. Now I can't get passed Google verification due to not having a keyboard! I've been trying to do it by voice which is just not working.. Almost wanted to throw phone at the wall lol... And you can only make so many attempts to enter Google verification via text n it locks you out!
I'm upset about this security feature !!!!!!
I've tried side loading via adb n laptop but it says error or apk file missing (might be cause I deleted some stock apps?) I've tried lg software update tool but it says downloading software with no progress so I gave up :/
Is there no fix for me unless a stock from/recovery is available???
Any help is appreciated! Thank you!
What happened:
