wedgemoose
I have never used it. I only need for Visual Voicemail.
I am currently using the Verizon one which they seemed to have thrown together quick. It's not even close to as good as it was.
The main featureIi need is to be able to reply. I used to be able to do it in the Verizon one. But now for some reason you can only reply with a text or e-mail. Plus the buttons are hard to click and stuff.
so i'm thinking of trying the google voice thing. But before I do, does anyone know if i can reply to a voicemail (verizon to verizon of course)?
I don't like installing and uninstalling. So I figured i would ask first
thanks
thanks
