Google Voice Problem
coreymcl
While trying to setup Google Voice to work as my voicemail every time it try's to configure my phone the app crashes, every time. Has anyone else tried this yet?
Yes and I didn't have a problem.
Did you go to the Google Voice Settings online and add your number? Also on the website, did you activate Google voicemail on that phone?
After that's done, you can go back to the app and do the set-up.
If you did all that already, then I don't know what else might be the problem.
I just uninstalled it and reinstalled it and this time it worked fine. I guess I should have tried that before posting this thread. Thanks
