GoSMS Pro: Did a factory reset, how to backup old SMSes?
desibuoy
I had moved GoSMS pro to SD card but after a factory reset and a re-install from Google Play, it won't show up the old SMSes like WhatsApp did... how do I get back my old SMSes???
Did you have your messages backed-up in any way? Otherwise a factory reset will have wiped them completely.
There are many SMS backup apps on the market, allowing backup to SD card or to the cloud, automatically or manually, as you prefer. I believe Go SMS can even (manually) back up messages to SD card (which will not be affected by a factory reset). But if you were not using any of these then I'm afraid the messages are gone.
Greetings desibuoy,
Like Hadron said, If you did not backup your sms before the factory reset then your sms are gone.
Moving the app to the SD card has nothing to do with backing up your sms's. There is a backup option in Gosms, but again it needed to be used before the factory reset.
Sorry
