GoSMS Pro Typing Interruption
I have a Galaxy S3 with Swiftkey 3 keyboard. Every time I am sending someone a text message using gosms pro, if a new message comes in while I am typing, the keyboard hides and interrupts my typing each time. This only happens when using gosms pro. Is there something I need to disable to prevent this from happening?
I don't use Go, so I can't confirm if there's a setting by which you can tweak that behavior, but you could always try another client to see if the issue persists.
Well, by the time I got home, there was an update for the goSMS Pro app addressing this exact issue (where the keyboard would close on you). Ran the update and all is well.
Thanks for your response, though.
