Can you provide any details on what steps you took to install Android on your PC? That would help us determine the proper method for obtaining root. :thumbup:
Android x86 already is rooted. You must install with read/write. The only thing is a lot of the apps won't work due to the architecture (arm/MIPS/x86_64) if you sent about installing a different android it would be the same. Just install superuser or SuperSU and install your architecture su
