Hey joel magpatoc - welcome to the forums and thanks for joining
I am not sure what you mean about activating your GPS... you should be able to turn it on by going "menu=>settings=>location services=>GPS satellites" this will turn on the GPS capabilities of your phone. You would normally need to have a mobile data enabled for the GPS to work, as most GPS apps require a data connection (to download maps). There are some GPS apps that do not require a data connection to work (such as navfree) that may be of interest to you though
When you say trial period, it tends to suggest that you are talking about a specific app where you only got a trial and would have to buy the app in order to keep using it. We would not be able to discuss getting around a trial period that has expired, as it would be against site rules.
You might like to check out Samsung Galaxy Y - Android Forums for more info, tips, tricks, help and advice on getting the most out of your mobile from other users of the same phone.
Hope you find this place useful - if you need any more help navigating the forums, let one of us guides know and we will try to point you in the right direction
