GPS- Charge vs Thunderbolt
Since the last update gps has been perfect outdoors. Indoors it can take longer to lock but it will.
If you have gps issues make sure you are on the latest update (ee4) and then do a factory reset. I had issues at first but the data wipe fixed it. The first lock might take a little while but after that it should be fine.
