W wallstreet123456 Well-Known Member Feb 16, 2010 #1 Can someone tell me how to enter GPS coordinates into the GPS? Is it possible to do that?
H hastings Newbie Feb 16, 2010 #2 Download geobeagle or GPS status from the market. Both of those allow you to enter coordinates
T takeshi Android Expert Feb 16, 2010 #3 wallstreet123456 said: Can someone tell me how to enter GPS coordinates into the GPS? Click to expand... You mean Google Maps/Nav (it's not "the GPS")? Just enter them into the search field. What format do you have the coordinates in? Or did you mean something else by your question?
R rawness Android Enthusiast Feb 16, 2010 #4 Yea, you can just type them into search. With or without the symbols should work, i.e.: 38
(G) Android Expert Feb 16, 2010 #5 Not meaning to hijack the thread, but is there any way to GET your GPS coordinates from Google Maps?
W wallstreet123456 Well-Known Member Feb 16, 2010 #6 rawness said: Yea, you can just type them into search. With or without the symbols should work, i.e.: 38 Click to expand...
