One of the features of the Samsung Galaxy S5 phone that I use a lot is GPS and Google Maps. Both for work and play. In fact, I've been using phone based GPS since my Nokia N80 days, some 9 years ago.
The S5 can pick up satellites very quickly and offers me a fix of within 5m, (16ft), in around 20 sec's or so on a clear day, outdoors in the garden at home.
In fact, so good is the S5 with GPS that I have abandoned using dedicated GPS equipment.
In my own home the GPS can even detect the part of the house I am in with a slightly longer fix time.
For anyone who is experiencing GPS location and/or fix time problems, there are a couple of things that you can do which may help... although it will not fix a broken/damaged GPS antenna or improve your GPS if your government offers a degraded or non existent service.
#1. On your phone go to Settings > Location > Mode > High accuracy is set to ON. I find that this setting has no discernible impact on my battery life. Using Power saving or GPS only will greatly degrade the accuracy and increase, considerably, the time for a fix. Then go to Settings > Wi-Fi and turn it on. I leave Wi-Fi enabled 24/7 as, once more, it has no discernible impact on my battery life, (I do, however, have Always allow scanning, unchecked in Advanced).
#2. Download GPS Status & Toolbox, free from the Play Store. There is a paid version but the free one will suffice. However, supporting the dev with the paid version is good.
#3. In GPS Status & Toolbox, go to Menu > Settings > GPS & Sensors > Auto-download AGPS data and choose how often you wish AGPS, (Assisted GPS), to be updated. I use once a day as it is only a few bytes of information. You may decide more or less. Also Sensor filtering. I have mine set to weak but you can experiment. A stronger sensor filter increases the GPS fix time a bit. Also, under Menu > Settings > Display & Tools > Keep the screen on... check this as you will need to see your screen in step #7.
#4. Other settings you can choose to suit yourself and your location, such as meters/feet, miles/kilometers, etc: Unrooted users can now go to #6
#5. For rooted users up to Android 4.3 only. (Not necessary) Download TopNTP, free from the Play Store and select your location. This now tells your GPS to use a local location service which can speed up your fix time. You can also try their suggested NTP service but I find that the local one is quicker/more accurate for me. (N.B. May not work on Lollipop or Marshmallow)
#6. Now take your phone outside, away from buildings if possible and with a clear view of the sky. Open GPS Status & Tools > Spanner icon (you can touch a blank area of the screen to bring this up) and select both Compass calibration and Calibrate pitch and roll and follow the instructions for calibration.
#7. Now, still outdoors, put your phone into Flight Mode so that the phone is only using its internal GPS for a fix and go to the aforementioned Spanner icon > Manage A-GPS state > Reset and then leave it for around 5-10 minutes on a flat surface or until you see on the screen... Error 10ft (or 3m). This is about as good as it gets and may vary depending on your location.
#8. Now, very carefully without moving the phone turn Flight Mode off and in Spanner icon > Manage A-GPS state > select Download and then exit GPS Status & Tools.
#9. Now either, rotate the phone a couple of times through its three axis or do some figures of 8's with the phone.
#10. Go to Google Maps in Satellite mode and see how quickly you get a reasonably accurate fix. Don't forget, you can zoom in on Google Maps to see how close you are by placing two fingers on the screen and moving them apart.
Because I am a heavy GPS user, I tend to do items #6 -> #8 once every month or two but for most peoples uses, once every three or four months should suffice, if that.
Since all the apps I have mentioned are free, you have nothing to lose by trying it. Hope it helps!
TOP TIP: You might also like to try Here Maps by Nokia, free from the Play Store, which allows you to download a state/country/continent/world maps and voice directions in advance to be stored on your SD card thus saving you data downloads by using the off-line mode.
See, also...
35 Galaxy S5 models - know yours???
Lollipop Update Problems - Dummies Guide
Galaxy S5, Fake Clone or Genuine - Dummies Guide
E&OE This guide is written solely for, and on behalf of, Android Forums and may not be reproduced, in part or whole, without permission.
See, also...
