GPS on it's own does not require data, and is not an additional charge. However many of the applications that use the GPS may use data. The best way around it is to disable the data when you don't want to use it in settings->Wireless & Networks ->Mobile Networks. If you just want to use google maps without data you can cache an area of the map, see Official Google Blog: “Download map area” added to Labs in Google Maps for Android
