KutuluKid
I am using the deodex CM10 and am having trouble with my GPS. I copied the gps.default.so and gps.goldfish.so to /hw folder and changed permissions and the libgps.utils.so and libloc_adapter.so to /lib and the gps.conf to /etc but get no gps. I noticed the owner and group were still set to the sdcard so i changed all to 0000 root. is that right? or should they be something else. I did not check to see what they were before overwriting. Thanks in advance for the help.
