Root GPS issues CM9
jordan0314
I am running CM9 alpha 3. Modem version is FC15. I turn on GPS and my phone won't find my location and give directions. Please help
Thanks
Jordan.
I am having the same issue as well with the update from CM9 update. i havent found a solution thinking of going to a different Rom that has GPS working
I figured out how to fix that problem. Just flash stock el29 from Odin. Then re-flash CM9 and g-apps. Now my GPS is working better then it ever was. Give it a try.
