Help gps issues
jordan0314
i would like to know why when i open my navigation app and put a address in it says searching for gps signal for 5 minutes before it will pull up a route. p.s my gps is on
Have you tried clicking on network assist under GPS settings? That may help cut that down some. Also I have heard using GPS toolbox, I believe that's the name of it, from the market has helped some as well.
GPS Test is good, it has a setting to Clear AGPS info and update AGPS info.
Also if your on Stock EL29 its known to have GPS issues.
Search the forums for different modems.
I am running Stock Rooted EL29 ROM/Kernel with FC15 Modem and all is great with my device.
