Help GPS Locked On
Noticed a slight problem over the last couple of days (possibly since the LFB update).
I unlock the phone to find the GPS icon on the left hand side of the screen, locked on, not flashing. In the notifications I have the usual 'Location set by GPS' as an ongoing, as it would be if I was using the Maps app or something similar, but I've not got an open apps.
I suspect an app is using GPS in the background, is there any way of telling which one (as I will likely remove it)?
