GPS/navigation
In principle not (with preloaded maps).
But with it you will have a faster start with the GPS signal :)
Or if you want to use the traffic info.
EDIT: And of course, with Google Maps navigation you must have a data connection.
Harry
Harry
thank you
might take a trip to texas next week, and just check the sprint coverage, and i should have 3g the whole way there
if your using Google navigation and you set the route before you set off on your trip then it will cache the route in your phone for when you have no 3g signal.
Google Maps version 5 is out in a matter of days and will allow you to cache full maps to your phone which you should be able to use with navigation too!
