Help GPS Notification and Location Services
dhj
Member
So, I have both Google and Standalone location services enabled (not sure if I should). The icon that always shows in the notification bar is the diamond with the cross through it with the three succeedingly larger parentheses-like curves on the right. I always thought that was the icon that showed when something is accessing GPS and therefore using battery.
Is this the icon that should be there? Or should I be seeing something else?
That icon will be shown whenever you have anything enabled in location services.
When the GPS is actually running, this icon will disappear, and a new GPS icon should pop up to replace it.
  • Like
Reactions: dhj
Yeah, I was confused by this as well. Most phones I've used have NO icon unless the GPS is actually being used to seek location. But on this phone, the icon you described is always there and then the little circular GPS icon appears all the way to the left when GPS is actually being used. Strange implementation if you ask me, but I guess you get used to it.
Just to clarify these icons are carrier specific. International version only has an icon when something is using GPS, not when it's simply enabled.
Also, some carriers put an icon in the top bar for NFC and others don't.
The little cross on top of the phone is there no matter what. It does not mean GPS is on. When you are using a location (like Google services) it adds a bunch of lines to the right of icon. The icon will be there no matter what however (even if you turn off all locations) When GPS is on and working a separate icon will appear altogether.
  • Like
Reactions: dhj
Thanks all.
So now I have to ask, do you enable any location services? What is the reasoning to do it or not? And are there better/worse reasons with the GSIII than previous phones?
Thanks all.
I usually only keep the Google location on. Only GPS when I need it.
The three locations are pretty self explaining. The Google one will be used in location services required by certain apps and weather. I am pretty sure my weather app I use from Beautiful Widgets won't update unless one of the locations is turned on. The Verizon one is for when ever VZW apps use location (VZ Navigator). And last is the stand alone GPS which uses satellite position and is used by some 3rd party applications. THe most accurate.
The reason people would enable them is how often they use applications that require their services. My Personally I turn them on in a as needed basis. Other people who travel more and require these locations would probably leave them on. Leaving them on will probably decrease battery performance, but its all about how you feel is important. You could argue since the battery size of the S3 is larger in stock, you can afford to leave some of these locations on.
Great explanation. I'll play with these settings for a few days and see what works for me. Thanks!
