Help Gps offline for HTC one X
AhBeng
The Maps application that already in my phone cant use when offline.. So got any suggestion to change it or using other apps?? Thanks for helping..
If you need just a supstitute for Maps you might have a look at OsmAnd.
It's maps you can download on your SD card/phone storage for every country.
So you won't need a data connection while using the maps.
And this OpenStreetMaps are better than Googles :)
But if you need a turn-by-turn car navigation you might have look at Navigon or CoPilot. These premium apps have their maps on the SD card/phone storage and can navigate without a data connection :)
Harry
