anonymised info about your location
... I don't understand how can the gps send data even when it's off or when the phone is without battery or turned off. it doesn't have any power to transmit data to satelites.
There's no such thing as being anonymous on a mobile phone, let alone one with GPS chips in it. They're enabled even when they're disabled via software for the explicit purpose of tracking for emergency personnel such as police, ambulance, etc.
Adding to that the ONLY way to COMPLETELY disable GPS on any device that contains it is to completely remove the locator chip from the unit which in itself will be a real pain. Or you can short it out, or damage it enough to where it'll still let the rest of the device work. Those are about it.
The satellites can/will collect any information that they're told to, and considering that London has Air to Ground Missles on civilian rooftops I'd say that within the next ten years GPS technology is going to come back to bite us in the ass. Let's be honest - How many GPS devices do YOU think the president is surrounded by on a daily basis?
WW3 is coming, and it's going to be an EPIC FAILURE for everyone since no economy is stable anymore.
Just in case you thought GPS is without its share of risk:
American researchers took control of a flying drone by "hacking" into its GPS system - acting on a $1,000 (
The safest way to prevent an app from getting your location is LBE Privacy Guard or some app like that
Then the only way would be use the phone without a sim card that connects to a network and use the gps standalone with an app that uses your position but doesn't play with it or sends it to somewhere unknown like google maps app or navigation which are most common
