GPS Questions !!
indtram
Hi!
I wanted to know if I can use my Tab for GPS Driving Instructions ???
The Tab has a GPS Sensor and all Software can be added from the SD Card.... so can it e used as a Daily Driving aid ??
If YES !!...what Software would you recommend. What accessory will I need...If any ????
I have downloaded Sygic but am quite unaware how to use it !!!
Earlier I had downloaded the FakeGPS Location from Android Market....it doesnot work !! It gives the message " Force Close"
To check if the GPS Sensor etc was working ...I downloaded the GPS Stat and it detects 8-10 Sats and Locks my position perfectly.
That is why I wanted to know if I could use for my Driving Assistance or no !!!!
I have upgraded to the latest Android v2.2 3965 on the Tab.
Looking for some feedback from the learned .
Thanxxx
You will need a Downloaded map, or have internet available.
I plan to do the same thing.
Havnt found and map software yet - but am sure its out there.
I can also use my cell phone as a personal hotspot for internet.
