Root GPS - Rooted 2.2.2 Moment
Zines
Hello,
I was wondering if anyone found a fix for the GPS issue. My GPS worked fine before my phone was rooted. Since I rooted it, it has stopped working. I know this is a known issue. I have searched though several forums and tried a few apps or patches that some people said it worked, at least initially. Nothing seems to be working for me.
All the ones that I tried seem to be showing my initial starting point is a few streets off. Then I found one that I thought was really going to work. My starting point was correct, but when I started driving it wouldn
Every Moment is different, what works for one doesn't work for another. Since going to 2.2, I've had to have a clear sky and keep the phone on the dash to keep a sat connection. I didn't have that problem in 2.1. My Wife's gps works great in rooted 2.1. I haven't downgraded myself because I rarely use gps and want to keep apps2sd. If rooted 2.1 is something you want to do, all of the links in post #13 in this thread should still be valid.
