GPS Send doesnt work Why
Evo4sickness
I wanst able to find any links or info on why the GPS Send app doesnt work. I was wondering if anybody has downloaded or used it. I tried it yesturday and it said I was 0.0.0.0 in the middle of the Ocean. So trying to figure out how to get it to work since when your in the app there is no turning it on at all or Menu options. I had my GPS on and like I said it didnt work with it off or on it made no difference.
Worked fine for me just now.
If you open up google maps will it locate you correctly with GPS on?
Try downloading an app called GPS Status. Hit menu>tools>manage a-gps state then reset and download.
Yeah I have no problem with my gps finding me at all. Ok I will download that one just dont understand why it would not work for.
Ok found the solution when I first opened the app the GPS wasnt on and figured you can turn it on and then it will detect my location. You have to have the GPS on before turning on the app works perfect now.
