Bytheseaside
Bought the Galaxy S3 Mini because I was fed up with my old HTC Wildfire S running out of memory. New phone is faster & clearer & has bags of memory! However, I run Allsport GPS to map my walks. It worked fine on the old HTC, but the Galaxy S3 Mini has great difficulty finding the GPS satellites. Once it has found the position, if it loses it, it takes an age to find it again. I can run the app with my HTC in my coat pocket. If I put the Mini in my pocket, it loses all the satellite data & won't even start the walk. It also seems much less able to load the maps. (This is 2G & not very strong signals). The HTC seems to load the maps better too. Unless someone can suggest a solution to the Mini satellite reception, I will have to use the HTC for my walks! Anyone got any ideas, please?
