Hi,
I use the GPS functions and My Tracks quite frequently on my DX. I was wondering if there was a way to check to see which satellites the DX locks on to and their strength - much like a GPS unit (Garmin, etc)?
I would like to use this information to check some settings while on trails as well as getting the Lat/Long of my position.
If I have to use an APP to do this can you recommend a good one?
Thanks!
Thanks!
