[Gps] Why Does Cold Start Take So Long?
Winfried
Oct 11, 2011
129
14
Hello
I know very little about how GPS works.
I noticed that after disabling GPS mode for a few days, even while standing on a street in the city, it can take several minutes for GPS to show my location, even after using GPS Status or GPS Test to reset and download A-GPS data over a 3G connection, and enabling Location in the Settings section.
Is that to be expected, or should I try something else?
FWIW, I use a Galaxy Nexus running CyanogeMod 11.
Thank you.
Hello Winfried,
There are a number of articles available from a Google search 'how does GPS work' which you may find interesting eg. GPS
As RyanB said I don't think you are experiencing anything unusual. If my GPS has been inactive for a while it can take what seems to be a very long time for the first fix, although I reckon it's a bit like a watched kettle !! Depending on which article you read 12 to 20 minutes is possible in poor conditions.
Also bear in mind that a city street is not necessarily an ideal place to be for that first fix. If you are surrounded by tall buildings you will have a restricted view of the sky, and although A-GPS will preload your GPS receiver with those satellites nearest to you, your receiver still has to electronically 'see' and lock on to them.
Hope this helps.
Upvote 0
You should have tried a stand alone GPS device from about 6-7 years ago. They would take forever, and then typically ask you about the date and time just to make sure they got it right. It could easily take over 5 minutes, particularly if you'd gone a long distance since turning the device off (e.g. fly from Seattle to Phoenix).
Upvote 0
BEST TECH IN 2023
Smartphones
