In this device GPS has a weird setup but it works very good. The idea is if you want to lock it up, first download androits GPS test from store and start the app, then go to location settings disable three options and then turn VZN location first, then Standalone GPS and do not activate google location services, after a few seconds you'll see the GPS lock sign at notification bar.
Instead of using androits app you could use any app tha request GPS hardware lock.
