OldPalmUser
I've been using my Optimus V for about a month now and today when I tried to use the navigation I couldn't get the GPS to toggle on. Wouldn't come on and display even the on status in the status bar. I'd been using the power widget but also couldn't get it to come on with changing the status thru the menu settings.
I'm new to Android and only have a few apps but though it was maybe one of those so tonight I ended up uninstalling ALL my apps, one by one, and rebooting after each - no luck. Then I decided what the heck and did the factory reset - still no GPS icon in the status bar and no GPS. (turned the phone off and removed the battery for 15+ minutes which didn't help either).
It did work fine when I first got the phone because I used it for navigation a couple times and did see the GPS icon when I turned it on and saw the icon indicating that it was communicating. Anyone have any ideas or suggestions what to try next???? Think I just have a defective phone???
I did have trouble at the beginning of the month with VM dropping my data connection and getting a no server connection message, but I contacted them and the data is working OK now and I'm assuming that VM doesn't have anything to do with the GPS on toggle . . .
Thanks - I really love this little smart phone!!
