Hi,
There are a few things you can try to improve the quality of the Bluetooth audio on your cell phone:
- Make sure the device you are connecting to is close to your phone. Bluetooth signals can be weakened by distance or obstacles.
- Try adjusting the audio settings on both your phone and the device you are connecting to. Some devices have settings specifically for audio quality that you can adjust.
- Make sure the device you are connecting to is compatible with your phone. Some devices may not be fully compatible with all phone models, which can affect audio quality.
- Try connecting to a different device and see if the issue persists.
- Restart your phone and the device you are connecting to. This can help to clear up any temporary issues that may be causing the problem.
- Check for any software updates for your phone and the device you are connecting to and install them if available.
- Try a different Bluetooth codec, like aptX or LDAC if your device support it.
These steps may help to improve the audio quality when using Bluetooth on your phone. If the problem persists, you may want to consider getting your phone checked by a professional or contacting the manufacturer for further assistance.
