Hi, I have a HTC Sensation 4G, 2.3.3 Gingerbread, , and I have a hunch this is an Android issue more than an HTC issue. The green call button (as well as the rest of the touch screen) is way too sensitive at times. What I'm most bothered by, is the location of the green call button, way to easy to accidentally press when browsing contacts, or especially when using the back button, etc. right underneath it. And then an unwanted call is on the way to whoever is last dialed in the contact list.
Any apps or workarounds to either relocate the call button, make it less sensitive, or to require a long press or double tap to call, or a confirm screen such as "are you sure you want to call this contact?"? Thanks. I tried Googling but can't find a specific answer.
