In order to create a group in your contacts go to your home screen and follow
these steps:
1. Tap contacts
2. Go to the "groups" tab - If the groups tab is not visible, you may have to
use the touchscreen to scroll left to right to find it. Once you find the
groups tab, please tap that option.
3. Once you are in the groups tab, tap the menu key.
4. Tap create and name your group.
5. Save the group name. When you save the group name, you will be sent back to
the groups menu.
6. From the groups menu, select the newly created group.
7. You will then be able to add contacts from your address book and then save.
To send out a group text:
1. From the home screen you will need to tap "messaging".
2. Tap the envelope icon to create a new message.
3. Next to the "To:" field there will be a contact icon. You will need to tap
the contact icon.
4. Tap groups
5. Select your group and add.
6. You will then be directed back to your message to create your text.
