Group Text Messaging
Welcome to the Android Forums!
There's no easy way to do this... you could specify each number to send separated by a comma but if you have a long list this might be time prohibitive. You can also try using a third party SMS app like Handcent. Another way to consider is using a third party app called "Contacts GroupU" with your existing SMS client.
http://market.android.com/details?id=com.groupu.android
From what I've been told the app has some quirks but it might help you do what you are attempting to do...
