Help Grrrrr.....A Few Problems.
I got my wildfire S a few weeks back, and it's the best phone i've had in some senses but other's then it's just annoying me!
Firstly - App's don't install properly, wierdly, apps i pay for, do without problem. I had to even install Angry Birds using an APK file. I also can't install the Facebook update app
Secondly - HTC Hub doesn't even work properly, Skins and widgets to name two, widgets download then they install like get to 100% but instead of saying 'Install Sucessful' they just vanish, Nothing installs. Wallpapers can be a bit funny at times too.
Thirdly - A Lack of memory. Jeez that fecking annoys me. I Run an app, Twitter for example, then go into the music player or go back into the music player, and the music player wont run as there is a lack of memory
Fourthly - Wallpapers! Jesus, that's annoying me, If a picture is full sized, i.e takes size of screen, why can't i just set the full image as a wallpaper, or is there a way to do so?
Cheers
You could well have got a faulty handset, because I've had my Wildfire S for about a month and haven't experienced a single issue with it - apps/games download no problem and can be easily found on the app screen and havent had any issue with memory. Not sure about the wallpaper now as I just use the default wallpapers included on the phone.
If you are having issues with the memory I would recommend downloading Fast Reboot Pro. It's less than
