bern_viking
Hello everybody
So, this Sunday, October 30th, almost all of Europe switched from DST to "Winter Time", clocks were set back one hour, you got more time in bed and all that.
And my Hero HTC has made a mess of reccuring events in its calendar.
I have two events on Mondays that started in October and go on until January, one from 0800 to 1200, the other 1300-1700. They were entered during DST, and Outlook manages to keep them at the correct hour. I sync with the HTC Sync application.
Not so the Heros Calendar, it has shifted every event from Nov. 1st to one hour earlier, 0700-1100 and 1200-1600. They stay correctly in Outlook.
As far as i can see, the timezone in my Hero and Outlook is set correctly to the same: UTC+1. In my Hero, there is no setting "DST on/off" (that I have managed to find).
I find this extremely bothersome and completely unacceptable for a calendar application in 2010. We've had DST for some years, Google, maybe you should realise that. Now I have to double check appointments and events in my calendar to see if they are offset. It *seems* only to affect those that are reccurring and go over the time change date, but who knows?
I'd like to know if anyone out there has a solution, a workaround, or if anybody else has experienced the same.
Thanks and Cheers
S.
(oh yeah, part 2 and following may be coming soon...)
Thanks and Cheers
S.
