Yes, some times my Elite Sliver will tell me phone not connected and within seconds it's reconnected, and it is on my hip, I have no solutions so far I just put up with it, I figure if enough complaints are made there will be an update to solve the problem, I hope. My biggest problem is using MOTOSPEAK with my S3 it when texting it shows buffering and not sent, but it did send???? And then to use the keyboard after texting with MotoSpeak you have to REBOOT, AND THEN IT TELLS YOU THAT TEST WITH MOTOSPEAK FAILED Hope they get that fixed it seems to be in the App not the device.
